Giriş
In order to upgrade your PowerBook's RAM or replace a faulty RAM card you will need first remove the existing RAM card.
Neye ihtiyacın var
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
To install the new RAM card, follow these steps in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
