Ana içeriğe geç
PowerBook 3400 M3553 Speaker Panel Replacement
Neye ihtiyacın var
  1. PowerBook 3400 M3553 Speaker Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Speaker Panel Replacement: adım 2, 2 resimden 1. PowerBook 3400 M3553 Speaker Panel Replacement: adım 2, 2 resimden 2.
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Speaker Panel Replacement, Keyboard: adım 3, 1 resimden 1.
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Speaker Panel Replacement: adım 4, 3 resimden 1. PowerBook 3400 M3553 Speaker Panel Replacement: adım 4, 3 resimden 2. PowerBook 3400 M3553 Speaker Panel Replacement: adım 4, 3 resimden 3.
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Speaker Panel Replacement: adım 5, 2 resimden 1. PowerBook 3400 M3553 Speaker Panel Replacement: adım 5, 2 resimden 2.
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
  6. PowerBook 3400 M3553 Speaker Panel Replacement, RAM: adım 6, 2 resimden 1. PowerBook 3400 M3553 Speaker Panel Replacement, RAM: adım 6, 2 resimden 2.
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
  7. PowerBook 3400 M3553 Speaker Panel Replacement, Speaker Panel: adım 7, 2 resimden 1. PowerBook 3400 M3553 Speaker Panel Replacement, Speaker Panel: adım 7, 2 resimden 2.
    • Disconnect the wires from the port.
  8. PowerBook 3400 M3553 Speaker Panel Replacement: adım 8, 1 resimden 1.
    • Remove the 7mm screw connecting the speaker panel to the computer.
  9. PowerBook 3400 M3553 Speaker Panel Replacement: adım 9, 2 resimden 1. PowerBook 3400 M3553 Speaker Panel Replacement: adım 9, 2 resimden 2.
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
  10. PowerBook 3400 M3553 Speaker Panel Replacement: adım 10, 2 resimden 1. PowerBook 3400 M3553 Speaker Panel Replacement: adım 10, 2 resimden 2.
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Mondragon
274 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G59
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,734
