Ana içeriğe geç
PowerBook G3 Lombard Hard Drive Replacement
Neye ihtiyacın var
    1. PowerBook G3 Lombard Hard Drive Replacement, Keyboard: adım 1, 1 resimden 1.
      • Turn the computer so that the ports are facing you.
      • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Hard Drive Replacement: adım 2, 1 resimden 1.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard Hard Drive Replacement: adım 3, 1 resimden 1.
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
      • In order to replace the keyboard, you must first remove the modem.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Hard Drive Replacement, Heat Shield: adım 4, 1 resimden 1.
      • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Hard Drive Replacement: adım 5, 1 resimden 1.
      • Lift the heat shield up and pull it toward you.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard Hard Drive Replacement: adım 6, 1 resimden 1.
      • Your laptop should look approximately like this.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Hard Drive Replacement, Modem: adım 7, 1 resimden 1.
      • Remove the two silver Phillips screws from the modem.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Hard Drive Replacement: adım 8, 1 resimden 1.
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard Hard Drive Replacement: adım 9, 1 resimden 1.
      • Disconnect the cable from the right side of the modem.
      FixBot'a Sor
      Yorum Ekle
    4. PowerBook G3 Lombard Hard Drive Replacement: adım 10, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Hard Drive Replacement, Processor: adım 11, 1 resimden 1.
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Hard Drive Replacement: adım 12, 1 resimden 1.
      • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
      • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard Hard Drive Replacement: adım 13, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Hard Drive Replacement, Hard Drive: adım 14, 1 resimden 1.
      • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
      • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Hard Drive Replacement: adım 15, 1 resimden 1.
      • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Hard Drive Replacement, Hard Drive: adım 16, 1 resimden 1.
      • Remove the four black Torx screws located at the four corners of the hard drive bracket.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Hard Drive Replacement: adım 17, 1 resimden 1.
      • Pull the connector cable out from the hard drive, applying even pressure while gently rocking up and down.
      • Be very careful to apply even pressure when removing the cable. If you torque too hard to either side, you may damage or destroy the hard drive's connector pins, rendering your data inaccessible.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 13,048
