Ana içeriğe geç
PowerBook G3 Lombard PRAM Battery Replacement
Neye ihtiyacın var
  1. PowerBook G3 Lombard PRAM Battery Replacement, Keyboard: adım 1, 1 resimden 1.
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard PRAM Battery Replacement: adım 2, 1 resimden 1.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard PRAM Battery Replacement: adım 3, 1 resimden 1.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard PRAM Battery Replacement, PRAM Battery: adım 4, 1 resimden 1.
    • Pull the battery cable directly up from the logic board.
  5. PowerBook G3 Lombard PRAM Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery from its holder by pulling up and to the left.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
2 Yorum
Step 4, 5 and 6 are useless for changing the PRAM battery..
Godzil - Yanıt
Seems the step I was referring to are no longer there!
Godzil -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 22
Her zaman: 10,932
