Ana içeriğe geç
PowerBook G3 Lombard Processor Replacement
Neye ihtiyacın var
    1. PowerBook G3 Lombard Processor Replacement, Keyboard: adım 1, 1 resimden 1.
      • Turn the computer so that the ports are facing you.
      • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Processor Replacement: adım 2, 1 resimden 1.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard Processor Replacement: adım 3, 1 resimden 1.
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
      • In order to replace the keyboard, you must first remove the modem.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Processor Replacement, Heat Shield: adım 4, 1 resimden 1.
      • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Processor Replacement: adım 5, 1 resimden 1.
      • Lift the heat shield up and pull it toward you.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard Processor Replacement: adım 6, 1 resimden 1.
      • Your laptop should look approximately like this.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Processor Replacement, PRAM Battery: adım 7, 1 resimden 1.
      • Pull the battery cable directly up from the logic board.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Processor Replacement: adım 8, 1 resimden 1.
      • Remove the battery from its holder by pulling up and to the left.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Processor Replacement, Modem: adım 9, 1 resimden 1.
      • Remove the two silver Phillips screws from the modem.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Processor Replacement: adım 10, 1 resimden 1.
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard Processor Replacement: adım 11, 1 resimden 1.
      • Disconnect the cable from the right side of the modem.
      FixBot'a Sor
      Yorum Ekle
    4. PowerBook G3 Lombard Processor Replacement: adım 12, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard Processor Replacement, Processor: adım 13, 1 resimden 1.
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard Processor Replacement: adım 14, 1 resimden 1.
      • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
      • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard Processor Replacement: adım 15, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 41
Her zaman: 6,406
