Ana içeriğe geç
PowerBook G3 Lombard Processor Replacement
Neye ihtiyacın var
  1. PowerBook G3 Lombard Processor Replacement, Keyboard: adım 1, 1 resimden 1.
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Processor Replacement: adım 2, 1 resimden 1.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Processor Replacement: adım 3, 1 resimden 1.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Processor Replacement, Heat Shield: adım 4, 1 resimden 1.
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Processor Replacement: adım 5, 1 resimden 1.
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Processor Replacement: adım 6, 1 resimden 1.
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Processor Replacement, PRAM Battery: adım 7, 1 resimden 1.
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard Processor Replacement: adım 8, 1 resimden 1.
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard Processor Replacement, Modem: adım 9, 1 resimden 1.
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard Processor Replacement: adım 10, 1 resimden 1.
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard Processor Replacement: adım 11, 1 resimden 1.
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard Processor Replacement: adım 12, 1 resimden 1.
  13. PowerBook G3 Lombard Processor Replacement, Processor: adım 13, 1 resimden 1.
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. PowerBook G3 Lombard Processor Replacement: adım 14, 1 resimden 1.
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. PowerBook G3 Lombard Processor Replacement: adım 15, 1 resimden 1.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 5,880
