Ana içeriğe geç
PowerBook G3 Lombard RAM Replacement
Neye ihtiyacın var
    1. PowerBook G3 Lombard RAM Replacement, Keyboard: adım 1, 1 resimden 1.
      • Turn the computer so that the ports are facing you.
      • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard RAM Replacement: adım 2, 1 resimden 1.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard RAM Replacement: adım 3, 1 resimden 1.
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
      • In order to replace the keyboard, you must first remove the modem.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard RAM Replacement, Heat Shield: adım 4, 1 resimden 1.
      • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard RAM Replacement: adım 5, 1 resimden 1.
      • Lift the heat shield up and pull it toward you.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard RAM Replacement: adım 6, 1 resimden 1.
      • Your laptop should look approximately like this.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard RAM Replacement, PRAM Battery: adım 7, 1 resimden 1.
      • Pull the battery cable directly up from the logic board.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard RAM Replacement: adım 8, 1 resimden 1.
      • Remove the battery from its holder by pulling up and to the left.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard RAM Replacement, Modem: adım 9, 1 resimden 1.
      • Remove the two silver Phillips screws from the modem.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard RAM Replacement: adım 10, 1 resimden 1.
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard RAM Replacement: adım 11, 1 resimden 1.
      • Disconnect the cable from the right side of the modem.
      FixBot'a Sor
      Yorum Ekle
    4. PowerBook G3 Lombard RAM Replacement: adım 12, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard RAM Replacement, Processor: adım 13, 1 resimden 1.
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Lombard RAM Replacement: adım 14, 1 resimden 1.
      • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
      • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Lombard RAM Replacement: adım 15, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G3 Lombard RAM Replacement, RAM: adım 16, 1 resimden 1.
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the RAM chip out.
      • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
633 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 9,287
