Ana içeriğe geç
PowerBook G3 Pismo Heat Sink Replacement
Neye ihtiyacın var
  1. PowerBook G3 Pismo Heat Sink Replacement, Keyboard: adım 1, 1 resimden 1.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
  2. PowerBook G3 Pismo Heat Sink Replacement: adım 2, 1 resimden 1.
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
  3. PowerBook G3 Pismo Heat Sink Replacement: adım 3, 1 resimden 1.
    • Your laptop should look approximately like this.
  4. PowerBook G3 Pismo Heat Sink Replacement, Heat Shield: adım 4, 1 resimden 1.
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
  5. PowerBook G3 Pismo Heat Sink Replacement: adım 5, 1 resimden 1.
  6. PowerBook G3 Pismo Heat Sink Replacement, Airport Card: adım 6, 1 resimden 1.
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
  7. PowerBook G3 Pismo Heat Sink Replacement: adım 7, 1 resimden 1.
    • Disconnect the antenna cable from the Airport card.
  8. PowerBook G3 Pismo Heat Sink Replacement, PRAM Battery: adım 8, 1 resimden 1.
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Pismo Heat Sink Replacement: adım 9, 1 resimden 1.
  10. PowerBook G3 Pismo Heat Sink Replacement, Heat Sink: adım 10, 1 resimden 1.
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
  11. PowerBook G3 Pismo Heat Sink Replacement: adım 11, 1 resimden 1.
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 4,867
