Ana içeriğe geç
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Turn the keyboard locking screw so that it is parallel to the space bar.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
  3. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
  6. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Skip this step if your computer does not have an Airport card installed.
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
  7. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Disconnect the antenna cable from the Airport card.
    • Disconnect the antenna cable from the Airport card.
  8. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull the battery cable directly up from the logic board.
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
  9. Bu adım çevrilmemiş. Çevrilmesine yardım edin
  10. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
  11. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Lift the heat sink up from the left side and pull it out.
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
  12. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Grasp the plastic tab on the processor's right side and pull it directly up.
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
  13. Bu adım çevrilmemiş. Çevrilmesine yardım edin
  14. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the black Torx screw from the right side of the modem.
    • Remove the black Torx screw from the right side of the modem.
    • Remove the small black plastic rectangle with four holes.
  15. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
    • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
  16. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Disconnect the cable from the right side of the modem.
    • Disconnect the cable from the right side of the modem.
Bitiş Çizgisi
Ekli Belgeler
iRobot
1 İtibar
647 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,461
