Giriş
How to remove the hard drive and its bracket from your computer.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
9 farklı kişi bu kılavuzu tamamladı.
