Ana içeriğe geç
PowerBook G3 Wallstreet Keyboard Replacement
Neye ihtiyacın var
    1. PowerBook G3 Wallstreet Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
      • Remove both expansion bay modules using the levers on the front of the computer.
      • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
      • Pull the tabs toward yourself and the keyboard will pop up.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G3 Wallstreet Keyboard Replacement: adım 2, 1 resimden 1.
      • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
      • Rest the keyboard on the trackpad.
      FixBot'a Sor
      Yorum Ekle
      • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook G3 Wallstreet Keyboard Replacement: adım 4, 1 resimden 1.
      • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
      FixBot'a Sor
      Yorum Ekle
    4. PowerBook G3 Wallstreet Keyboard Replacement: adım 5, 1 resimden 1.
      • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
      • Once the strain relief cables are free, lift the keyboard off.
      FixBot'a Sor
      Yorum Ekle
    5. PowerBook G3 Wallstreet Keyboard Replacement: adım 6, 1 resimden 1.
      • Your laptop should look approximately like this.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
3Kılavuz Yorumları
The first iFixit guide?
ljcool2006 - Yanıt Paylaş
Yes sir! (text minimum)
guardian10 - Yanıt Paylaş
Yes yes yes yes
Lol - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 90
Her zaman: 22,500
