Ana içeriğe geç
PowerBook G3 Wallstreet PMU Replacement
Neye ihtiyacın var
  1. PowerBook G3 Wallstreet PMU Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G3 Wallstreet PMU Replacement: adım 2, 1 resimden 1.
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    FixBot'a Sor
    Yorum Ekle
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G3 Wallstreet PMU Replacement: adım 4, 1 resimden 1.
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G3 Wallstreet PMU Replacement: adım 5, 1 resimden 1.
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G3 Wallstreet PMU Replacement: adım 6, 1 resimden 1.
    • Your laptop should look approximately like this.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook G3 Wallstreet PMU Replacement, Heat Shield: adım 7, 1 resimden 1.
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
    FixBot'a Sor
    Yorum Ekle
  7. PowerBook G3 Wallstreet PMU Replacement: adım 8, 1 resimden 1.
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
    FixBot'a Sor
    Yorum Ekle
  8. PowerBook G3 Wallstreet PMU Replacement, Hard Drive: adım 9, 1 resimden 1.
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
    FixBot'a Sor
    Yorum Ekle
  9. PowerBook G3 Wallstreet PMU Replacement: adım 10, 1 resimden 1.
    • Grasp the hard drive bracket on the left side and pull up and to the left.
    FixBot'a Sor
    Yorum Ekle
  10. PowerBook G3 Wallstreet PMU Replacement: adım 11, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  11. PowerBook G3 Wallstreet PMU Replacement, Processor: adım 12, 1 resimden 1.
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
    FixBot'a Sor
    Yorum Ekle
  12. PowerBook G3 Wallstreet PMU Replacement, Modem: adım 13, 1 resimden 1.
    • Remove the single Phillips screw from the modem.
    • Disconnect the orange PMU cable by pulling it directly up.
    FixBot'a Sor
    Yorum Ekle
  13. PowerBook G3 Wallstreet PMU Replacement: adım 14, 1 resimden 1.
    • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Remove the modem by sliding it up and to the right.
    FixBot'a Sor
    Yorum Ekle
  14. PowerBook G3 Wallstreet PMU Replacement: adım 15, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  15. PowerBook G3 Wallstreet PMU Replacement, Clutch Cover: adım 16, 1 resimden 1.
    • Push the display back so that it lies flat.
    • Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
    • Repeat the previous step on the left side.
    FixBot'a Sor
    Yorum Ekle
  16. PowerBook G3 Wallstreet PMU Replacement: adım 17, 1 resimden 1.
    • Lift the clutch cover off by rotating it up and then toward you.
    FixBot'a Sor
    Yorum Ekle
  17. PowerBook G3 Wallstreet PMU Replacement, Display: adım 18, 1 resimden 1.
    • Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
    FixBot'a Sor
    Yorum Ekle
  18. PowerBook G3 Wallstreet PMU Replacement: adım 19, 1 resimden 1.
    • Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
    • Make sure that both cables are free from the plastic casing before proceeding to the next step.
    FixBot'a Sor
    Yorum Ekle
  19. PowerBook G3 Wallstreet PMU Replacement: adım 20, 1 resimden 1.
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black T8 Torx screws.
    FixBot'a Sor
    Yorum Ekle
  20. PowerBook G3 Wallstreet PMU Replacement: adım 21, 1 resimden 1.
    • Turn the laptop back around so that the screen faces you.
    • Adjust the display so that it is in a vertical position.
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts
    FixBot'a Sor
    Yorum Ekle
  21. PowerBook G3 Wallstreet PMU Replacement: adım 22, 1 resimden 1.
    • Your laptop should look like this.
    FixBot'a Sor
    Yorum Ekle
  22. PowerBook G3 Wallstreet PMU Replacement, Upper Case: adım 23, 1 resimden 1.
    • Remove the four T8 Torx screws from the upper case.
    FixBot'a Sor
    Yorum Ekle
  23. PowerBook G3 Wallstreet PMU Replacement: adım 24, 1 resimden 1.
    • Turn the laptop over.
    • Remove the eight T8 Torx screws from the bottom casing.
    • There are two longer screws in the front left and front right corners; make sure to put them back in the proper place when reassembling.
    FixBot'a Sor
    Yorum Ekle
  24. PowerBook G3 Wallstreet PMU Replacement: adım 25, 1 resimden 1.
    • Disengage the small locking tab by pressing in on the upper case to the right of the PMU connector.
    • Lift the upper case up just enough so that the tab rests on its metal bracket.
    FixBot'a Sor
    Yorum Ekle
  25. PowerBook G3 Wallstreet PMU Replacement: adım 26, 1 resimden 1.
    • Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cable.
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
    FixBot'a Sor
    Yorum Ekle
  26. PowerBook G3 Wallstreet PMU Replacement: adım 27, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  27. PowerBook G3 Wallstreet PMU Replacement, PRAM Battery: adım 28, 1 resimden 1.
    • Disconnect the multicolor cable from the right side of the PMU.
    FixBot'a Sor
    Yorum Ekle
  28. PowerBook G3 Wallstreet PMU Replacement: adım 29, 1 resimden 1.
    • Free the battery cable from the upper case.
    FixBot'a Sor
    Yorum Ekle
  29. PowerBook G3 Wallstreet PMU Replacement: adım 30, 1 resimden 1.
    • Use a spudger or the tips of your fingers to pry up the PRAM battery and free it from its housing.
    FixBot'a Sor
    Yorum Ekle
  30. PowerBook G3 Wallstreet PMU Replacement, PMU: adım 31, 1 resimden 1.
    • Remove the single T8 Torx screw from the front left corner of the PMU.
    • Lift up the front edge of the PMU and disconnect the three smaller orange ribbon cables (two on the left side of the large PMU cable, and one on the right side) that attach to the underside of the PMU from the upper case.
    FixBot'a Sor
    Yorum Ekle
  31. PowerBook G3 Wallstreet PMU Replacement: adım 32, 1 resimden 1.
    • Turn the upper case over and pull the PMU connector cable up from the upper case.
    FixBot'a Sor
    Yorum Ekle
  32. PowerBook G3 Wallstreet PMU Replacement: adım 33, 1 resimden 1.
    • Turn the upper case back over and slide the PMU out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 6,151
