Ana içeriğe geç
PowerBook G3 Wallstreet Processor Replacement
Neye ihtiyacın var
  1. PowerBook G3 Wallstreet Processor Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G3 Wallstreet Processor Replacement: adım 2, 1 resimden 1.
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    FixBot'a Sor
    Yorum Ekle
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G3 Wallstreet Processor Replacement: adım 4, 1 resimden 1.
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G3 Wallstreet Processor Replacement: adım 5, 1 resimden 1.
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G3 Wallstreet Processor Replacement: adım 6, 1 resimden 1.
    • Your laptop should look approximately like this.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook G3 Wallstreet Processor Replacement, Heat Shield: adım 7, 1 resimden 1.
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
    FixBot'a Sor
    Yorum Ekle
  7. PowerBook G3 Wallstreet Processor Replacement: adım 8, 1 resimden 1.
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
    FixBot'a Sor
    Yorum Ekle
  8. PowerBook G3 Wallstreet Processor Replacement, Hard Drive: adım 9, 1 resimden 1.
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
    FixBot'a Sor
    Yorum Ekle
  9. PowerBook G3 Wallstreet Processor Replacement: adım 10, 1 resimden 1.
    • Grasp the hard drive bracket on the left side and pull up and to the left.
    FixBot'a Sor
    Yorum Ekle
  10. PowerBook G3 Wallstreet Processor Replacement: adım 11, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  11. PowerBook G3 Wallstreet Processor Replacement, Processor: adım 12, 1 resimden 1.
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 92
Her zaman: 9,166
