Ana içeriğe geç
PowerBook G4 Aluminum 12" 1-1.5 GHz Airport Extreme Card Replacement
Neye ihtiyacın var
  1. PowerBook G4 Aluminum 12" 1-1.5 GHz Airport Extreme Card Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 12" 1-1.5 GHz Airport Extreme Card Replacement, Airport Extreme Card: adım 2, 1 resimden 1.
    • Flip down the door on the right side of the battery compartment.
  3. PowerBook G4 Aluminum 12" 1-1.5 GHz Airport Extreme Card Replacement: adım 3, 1 resimden 1.
    • Use a spudger or flathead screwdriver to disconnect the Airport antenna from the card.
  4. PowerBook G4 Aluminum 12" 1-1.5 GHz Airport Extreme Card Replacement: adım 4, 1 resimden 1.
    • Grasp the plastic tab and pull the card out all the way.
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 21,130
