Ana içeriğe geç
PowerBook G4 Aluminum 12" 867 MHz RAM Replacement
Neye ihtiyacın var
    1. PowerBook G4 Aluminum 12" 867 MHz RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Use a coin to turn the battery locking screw 90 degrees to the right.
      • Lift the battery out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. PowerBook G4 Aluminum 12" 867 MHz RAM Replacement, RAM: adım 2, 1 resimden 1.
      • Remove the four Phillips screws from the memory door.
      • Slide the memory door away from the memory compartment.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook G4 Aluminum 12" 867 MHz RAM Replacement: adım 3, 1 resimden 1.
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 11,135
