Giriş
Accessing the RAM is easy and requires only a Phillips screwdriver.
Neye ihtiyacın var
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
28 farklı kişi bu kılavuzu tamamladı.
