Ana içeriğe geç
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement
Neye ihtiyacın var
  1. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement, Upper Case: adım 2, 1 resimden 1.
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 3, 1 resimden 1.
    • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
  4. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 4, 1 resimden 1.
    • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Remove the three 3 mm Phillips screws.
    • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  5. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 5, 1 resimden 1.
    • Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
  6. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 6, 1 resimden 1.
    • Rotate the computer 90 degrees clockwise, so that the ports face you.
  7. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 7, 1 resimden 1.
    • Turn the computer over and open the display.
    • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
  8. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 8, 1 resimden 1.
    • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 9, 1 resimden 1.
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 10, 1 resimden 1.
    • Remove the orange tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board.
    • Remove the upper case from the computer.
  11. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement, Battery Connector: adım 11, 1 resimden 1.
    • Disconnect the sleep light cable from the logic board to gain access to the battery connector cable beneath it.
  12. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 12, 1 resimden 1.
    • Disconnect the battery connector cable from beneath the logic board.
    • While it's easier to pull the thick battery connector cable out with your fingers, a spudger will help you push it back into place when putting the computer back together.
  13. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 13, 1 resimden 1.
    • Remove the two silver Phillips screws from the battery connector.
    • Remove a third Phillips screw near the bottom left corner of the hard drive that pins down a ground loop.
    • The screws with the larger heads go on the battery connector.
  14. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement: adım 14, 1 resimden 1.
    • Lift the battery connector out of the computer, removing tape as necessary.
Sonuç
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 7,346
