Giriş
Replacing the factory-installed Bluetooth 1.1 board.
Parçalar
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Using a spudger, pry up the Bluetooth board from the cavity in front of the battery compartment.
2 farklı kişi bu kılavuzu tamamladı.
