Giriş
This guide is only used as a prereq to other guides requiring rear bezel removed.
Parçalar
Hiçbir parça belirtilmedi.
Remove the single Phillips screw from the lower left and right corners of the display.
Insert the flat end of a spudger between the front display bezel and the plastic rim attached to the rear bezel near the lower right corner of the display.
While carefully prying the rear display bezel away from the display assembly, use a small flathead screwdriver to pry the small steel clip nearest the bottom right corner of the display away from the edge of the front display bezel.
Repeat the above procedure until you've released all the clips along the right side of the display.
Bir başkası bu kılavuzu tamamladı.
