Giriş
Replace a worn out battery for longer intervals between recharging.
Aletler
Hiçbir alete gerek yok.
Parçalar
  1. Use your thumbs to push the two battery retaining tabs away from the battery. The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
Bir Yorum
Where can I find new condition batteries for this. I can’t seem to find any compatable ones.
Legendary Ocelot - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 4
Her zaman: 2,683
