Ana içeriğe geç
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement
Neye ihtiyacın var
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement, Battery: adım 1, 2 resimden 1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Where can I find new condition batteries for this. I can’t seem to find any compatable ones.
Legendary Ocelot - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 3,157
