Ana içeriğe geç
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Memory Door Replacement
Neye ihtiyacın var
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Memory Door Replacement, Battery: adım 1, 2 resimden 1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Memory Door Replacement, Battery: adım 1, 2 resimden 2.
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Memory Door Replacement, Memory Door: adım 2, 1 resimden 1.
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Memory Door Replacement: adım 3, 2 resimden 1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Memory Door Replacement: adım 3, 2 resimden 2.
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,296
