Ana içeriğe geç
PowerBook G4 Titanium DVI Airport Card Replacement
Neye ihtiyacın var
  1. PowerBook G4 Titanium DVI Airport Card Replacement, Battery: adım 1, 2 resimden 1. PowerBook G4 Titanium DVI Airport Card Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: adım 2, 2 resimden 1. PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: adım 2, 2 resimden 2.
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI Airport Card Replacement, Airport Card: adım 3, 1 resimden 1.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 22,554
