Ana içeriğe geç
PowerBook G4 Titanium DVI DC-In Board Replacement
Neye ihtiyacın var
  1. PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: adım 1, 2 resimden 1. PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: adım 2, 2 resimden 1. PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: adım 2, 2 resimden 2.
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G4 Titanium DVI DC-In Board Replacement, DC-In Board: adım 3, 1 resimden 1.
    • Disconnect the large DC-In connector from the right side of the logic board.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G4 Titanium DVI DC-In Board Replacement: adım 4, 1 resimden 1.
    • Remove the two T6 Torx screws from the DC-In board.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G4 Titanium DVI DC-In Board Replacement: adım 5, 1 resimden 1.
    • Lift the DC-In board out of the computer by pulling up and away from you.
    • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
    • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 16,065
