Ana içeriğe geç
PowerBook G4 Titanium DVI Display Replacement
Neye ihtiyacın var
  1. PowerBook G4 Titanium DVI Display Replacement, Battery: adım 1, 2 resimden 1. PowerBook G4 Titanium DVI Display Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G4 Titanium DVI Display Replacement, Keyboard: adım 2, 1 resimden 1.
    • Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G4 Titanium DVI Display Replacement: adım 3, 1 resimden 1.
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G4 Titanium DVI Display Replacement: adım 4, 1 resimden 1.
    • Your laptop should look approximately like this.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G4 Titanium DVI Display Replacement, RAM: adım 5, 1 resimden 1.
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook G4 Titanium DVI Display Replacement, Lower Case: adım 6, 2 resimden 1. PowerBook G4 Titanium DVI Display Replacement, Lower Case: adım 6, 2 resimden 2.
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    FixBot'a Sor
    Yorum Ekle
  7. PowerBook G4 Titanium DVI Display Replacement, Airport Card: adım 7, 1 resimden 1.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    FixBot'a Sor
    Yorum Ekle
  8. PowerBook G4 Titanium DVI Display Replacement, Hard Drive: adım 8, 1 resimden 1.
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    FixBot'a Sor
    Yorum Ekle
  9. PowerBook G4 Titanium DVI Display Replacement: adım 9, 1 resimden 1.
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    FixBot'a Sor
    Yorum Ekle
  10. PowerBook G4 Titanium DVI Display Replacement: adım 10, 1 resimden 1.
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    FixBot'a Sor
    Yorum Ekle
  11. PowerBook G4 Titanium DVI Display Replacement: adım 11, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  12. PowerBook G4 Titanium DVI Display Replacement, Optical Drive Removal: adım 12, 1 resimden 1.
    • Disconnect and remove the indicated orange ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  13. PowerBook G4 Titanium DVI Display Replacement: adım 13, 1 resimden 1.
    • Disconnect the pink and white inverter cable from the inverter board.
    • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
    FixBot'a Sor
    Yorum Ekle
  14. PowerBook G4 Titanium DVI Display Replacement: adım 14, 1 resimden 1.
    • Remove the two silver T8 Torx screws from the black plastic bar.
    • Lift the black plastic bar out.
    • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
    FixBot'a Sor
    Yorum Ekle
  15. PowerBook G4 Titanium DVI Display Replacement: adım 15, 1 resimden 1.
    • Disconnect the two orange connectors from the logic board, removing tape as necessary.
    FixBot'a Sor
    Yorum Ekle
  16. PowerBook G4 Titanium DVI Display Replacement: adım 16, 1 resimden 1.
    • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
    FixBot'a Sor
    Yorum Ekle
  17. PowerBook G4 Titanium DVI Display Replacement: adım 17, 1 resimden 1.
    • Remove the drive by lifting the right edge up and out of the computer.
    FixBot'a Sor
    Yorum Ekle
  18. PowerBook G4 Titanium DVI Display Replacement, DC-In Board: adım 18, 1 resimden 1.
    • Disconnect the large DC-In connector from the right side of the logic board.
    FixBot'a Sor
    Yorum Ekle
  19. PowerBook G4 Titanium DVI Display Replacement: adım 19, 1 resimden 1.
    • Remove the two T6 Torx screws from the DC-In board.
    FixBot'a Sor
    Yorum Ekle
  20. PowerBook G4 Titanium DVI Display Replacement: adım 20, 1 resimden 1.
    • Lift the DC-In board out of the computer by pulling up and away from you.
    • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
    • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
    FixBot'a Sor
    Yorum Ekle
  21. PowerBook G4 Titanium DVI Display Replacement, Modem Filter Board: adım 21, 1 resimden 1.
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over and place it on the cloth.
    • Disconnect the four indicated connectors from the logic board.
    • The large multicolor cable may be difficult to free.
    • The top center cable may not need to be disconnected to remove the modem filter board. It connects to the logic board fan to its immediate left, which is attached to the logic board itself.
    FixBot'a Sor
    Yorum Ekle
  22. PowerBook G4 Titanium DVI Display Replacement: adım 22, 1 resimden 1.
    • Remove the T8 Torx screw near the heat pipe.
    FixBot'a Sor
    Yorum Ekle
  23. PowerBook G4 Titanium DVI Display Replacement: adım 23, 1 resimden 1.
    • Disconnect the two connectors from the modem filter board.
    • To the immediate right of the modem filter board, the heatsink has two sets of five fins with a double-wide space in between them. This space is where the gray & black coiled wire is supposed to go to ensure a flush fit.
    FixBot'a Sor
    Yorum Ekle
  24. PowerBook G4 Titanium DVI Display Replacement: adım 24, 1 resimden 1.
    • Remove the T6 Torx screw from the modem filter board.
    FixBot'a Sor
    Yorum Ekle
  25. PowerBook G4 Titanium DVI Display Replacement: adım 25, 1 resimden 1.
    • Remove the modem filter board from the computer by pulling up and to the right.
    • There is a small plastic post which helps hold the modem filter board in place. You need to clear this post to remove the modem filter board from the computer.
    FixBot'a Sor
    Yorum Ekle
  26. PowerBook G4 Titanium DVI Display Replacement, Logic Board: adım 26, 1 resimden 1.
    • Turn the G4 over.
    • Remove the seven T8 Torx screws from the logic board.
    • The five black screws go on the right side of the logic board, the large silver screw goes at the top, and the small silver screw is located on the left side.
    FixBot'a Sor
    Yorum Ekle
  27. PowerBook G4 Titanium DVI Display Replacement: adım 27, 1 resimden 1.
    • Disconnect the 5 indicated connectors from the logic board, removing tape as necessary.
    • Reassembly Tip: Reseating the logic board will be much easier if you use kapton tape to hold these five connectors out of the way until it is in place.
    • Caution: If taping the connectors back, be careful not to use tape with anything but very weak adhesive (i.e. kapton tape). Even electrical tape can pull the paint off the hinges when removed.
    FixBot'a Sor
    Yorum Ekle
  28. PowerBook G4 Titanium DVI Display Replacement: adım 28, 1 resimden 1.
    • Carefully lift the logic board up and pull it away from you.
    • This step requires some force, but if the logic board will not come up, make sure that you have removed all the necessary screws and connectors. Warming the heatsink with a heatgun or blow dryer will help release the logic board.
    • On 800 MHz and above G4s, you must disconnect the fan cable from the logic board before you lift the board entirely off.
    FixBot'a Sor
    Yorum Ekle
  29. PowerBook G4 Titanium DVI Display Replacement: adım 29, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  30. PowerBook G4 Titanium DVI Display Replacement, PC Card Cage: adım 30, 1 resimden 1.
    • Remove the two T8 Torx screws that secure the PC Card cage.
    • Remove the 4 mm hex nut from the PC Card cage.
    FixBot'a Sor
    Yorum Ekle
  31. PowerBook G4 Titanium DVI Display Replacement: adım 31, 1 resimden 1.
    • Remove the PC Card cage by pulling it to the right and twisting slightly toward you.
    FixBot'a Sor
    Yorum Ekle
    • Remove the fan or placeholder from the computer.
    • If you have a 667 MHz computer there is no fan in this location and just a placeholder bracket.
    FixBot'a Sor
    Yorum Ekle
    • Performing the following steps incorrectly can easily damage the display and render it inoperable. The multicolored display data cable is especially fragile.
    • Remove the four black T8 Torx screws from the plastic framework.
    FixBot'a Sor
    Yorum Ekle
  32. PowerBook G4 Titanium DVI Display Replacement: adım 34, 1 resimden 1.
    • Turn the G4 over.
    • Remove the five silver T8 Torx screws from the metal framework.
    FixBot'a Sor
    Yorum Ekle
  33. PowerBook G4 Titanium DVI Display Replacement: adım 35, 1 resimden 1.
    • Turn the G4 over.
    • Grasp the plastic framework and pull directly up.
    FixBot'a Sor
    Yorum Ekle
  34. PowerBook G4 Titanium DVI Display Replacement: adım 36, 1 resimden 1.
    • Disconnect and remove the pink and white inverter cable, removing tape as necessary.
    FixBot'a Sor
    Yorum Ekle
    • Disconnect the audio connector cable on the right side of the computer.
    FixBot'a Sor
    Yorum Ekle
  35. PowerBook G4 Titanium DVI Display Replacement: adım 38, 1 resimden 1.
    • Position the display approximately at a 45 degree angle and rest the computer on a soft cloth with the back panel ports facing up.
    • Remove the two T8 Torx screws from each clutch cover.
    FixBot'a Sor
    Yorum Ekle
  36. PowerBook G4 Titanium DVI Display Replacement: adım 39, 1 resimden 1.
    • Close the display and pull off both clutch covers. You can use a non-metal flathead screwdriver if the clutch covers do not come off easily.
    FixBot'a Sor
    Yorum Ekle
  37. PowerBook G4 Titanium DVI Display Replacement: adım 40, 1 resimden 1.
    • Open the back panel port cover and remove the four T6 Torx screws.
    • The upper screw on each side fastens a small metal mount in place. Be sure to put this part back in when reassembling the computer.
    FixBot'a Sor
    Yorum Ekle
  38. PowerBook G4 Titanium DVI Display Replacement: adım 41, 1 resimden 1.
    • Open the display to a 90 degree angle. Rest the trackpad face down on your work surface and allow the display to hang over the edge. If possible, adjust your chair or worksurface height so the display will rest on your legs and the trackpad will lie flat on the worksurface.
    • Remove the four T8 Torx screws which fasten the display to the trackpad. The screw closest to the display data cable has a tapered head.
    FixBot'a Sor
    Yorum Ekle
  39. PowerBook G4 Titanium DVI Display Replacement: adım 42, 1 resimden 1.
    • Grasp the metal heat exchanger and pull up and away from you. You may need to move the inverter cable on the right side of the computer in order to rotate the heat exchanger.
    FixBot'a Sor
    Yorum Ekle
  40. PowerBook G4 Titanium DVI Display Replacement: adım 43, 1 resimden 1.
    • Lift up the metal brackets on either side of the upper case.
    FixBot'a Sor
    Yorum Ekle
  41. PowerBook G4 Titanium DVI Display Replacement: adım 44, 1 resimden 1.
    • Carefully thread the inverter cable on the right side through the slot in the upper case.
    • Carefully thread the display and backlight cables individually through the slot in the upper case. Be very careful with the display cable as it is easily damaged.
    • Remove the display assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
37 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
2Kılavuz Yorumları
This walk through is almost useless: it makes something long and complicated out of something simple and easy. The only thing you have to take out is the logic board in order to access the back of the display attachments. The heat exchanger may stay in too. Just be careful with the screen wires.
fcapeilleres - Yanıt Paylaş
Same here. This guide may be using imagery from the pre-A1025 model PowerBook G4 Titanium’s, which would explain this discrepancy.
Anthony - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 93
Her zaman: 37,280
