Ana içeriğe geç
PowerBook G4 Titanium DVI Optical Drive Replacement
Neye ihtiyacın var
  1. PowerBook G4 Titanium DVI Optical Drive Replacement, Battery: adım 1, 2 resimden 1. PowerBook G4 Titanium DVI Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G4 Titanium DVI Optical Drive Replacement, Lower Case: adım 2, 2 resimden 1. PowerBook G4 Titanium DVI Optical Drive Replacement, Lower Case: adım 2, 2 resimden 2.
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G4 Titanium DVI Optical Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 4, 1 resimden 1.
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 6, 1 resimden 1.
    • Your laptop should look approximately like this.
    FixBot'a Sor
    Yorum Ekle
  7. PowerBook G4 Titanium DVI Optical Drive Replacement, Optical Drive Removal: adım 7, 1 resimden 1.
    • Disconnect and remove the indicated orange ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  8. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 8, 1 resimden 1.
    • Disconnect the pink and white inverter cable from the inverter board.
    • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
    FixBot'a Sor
    Yorum Ekle
  9. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 9, 1 resimden 1.
    • Remove the two silver T8 Torx screws from the black plastic bar.
    • Lift the black plastic bar out.
    • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
    FixBot'a Sor
    Yorum Ekle
  10. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 10, 1 resimden 1.
    • Disconnect the two orange connectors from the logic board, removing tape as necessary.
    FixBot'a Sor
    Yorum Ekle
  11. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 11, 1 resimden 1.
    • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
    FixBot'a Sor
    Yorum Ekle
  12. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 12, 1 resimden 1.
    • Remove the drive by lifting the right edge up and out of the computer.
    FixBot'a Sor
    Yorum Ekle
  13. PowerBook G4 Titanium DVI Optical Drive Replacement, Optical Drive: adım 13, 1 resimden 1.
    • Remove the 4 T6 Torx screws securing the modem and inverter boards to the optical drive.
    • Lift the inverter board off of the optical drive.
    • Lift the modem off of the optical drive, carefully guiding the orange cable through the metal mounting bracket.
    FixBot'a Sor
    Yorum Ekle
  14. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 14, 1 resimden 1.
    • Disconnect the orange optical drive ribbon from the back of the drive.
    FixBot'a Sor
    Yorum Ekle
  15. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 15, 1 resimden 1.
    • If your new optical drive already has a bracket and bezel for your model, then you are done.
    • Remove the 2 Phillips screws from the side with the longer bumper.
    • Remove the bracket from the optical drive.
    FixBot'a Sor
    Yorum Ekle
  16. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 16, 1 resimden 1.
    • Remove the 2 Phillips screws from the other side of the optical drive.
    FixBot'a Sor
    Yorum Ekle
  17. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 17, 1 resimden 1.
    • Depending on the new drive's model, the bezel on your old drive may not transfer to the new one. The bezel is not strictly necessary, and the drive will probably work fine without it, but you should transfer it if you can in order to ensure proper alignment with the case.
    • Remove the 4 Phillips #00 screws from the top of the optical drive.
    FixBot'a Sor
    Yorum Ekle
  18. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 18, 1 resimden 1.
    • Lift up on the thinner edge of the optical drive so that you can access and depress the recessed black tab using a spudger.
    FixBot'a Sor
    Yorum Ekle
  19. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 19, 1 resimden 1.
    • Use a spudger to depress and release the two black tabs on top of the optical drive directly over the bezel.
    FixBot'a Sor
    Yorum Ekle
  20. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 20, 1 resimden 1.
    • Use a spudger to depress and release the black tab on the left side of the optical drive.
    FixBot'a Sor
    Yorum Ekle
  21. PowerBook G4 Titanium DVI Optical Drive Replacement: adım 21, 1 resimden 1.
    • Carefully remove the bezel from the optical drive, minding the two plastic tabs on the bottom, which may catch.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 55
Her zaman: 14,858
