Ana içeriğe geç
PowerBook G4 Titanium Mercury DVD Drive Replacement
Neye ihtiyacın var
  1. PowerBook G4 Titanium Mercury DVD Drive Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G4 Titanium Mercury DVD Drive Replacement: adım 2, 1 resimden 1.
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G4 Titanium Mercury DVD Drive Replacement: adım 3, 1 resimden 1.
    • Your laptop should look approximately like this.
    FixBot'a Sor
    Yorum Ekle
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G4 Titanium Mercury DVD Drive Replacement: adım 5, 1 resimden 1.
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G4 Titanium Mercury DVD Drive Replacement: adım 6, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook G4 Titanium Mercury DVD Drive Replacement, DVD Drive: adım 7, 1 resimden 1.
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
    • Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
    FixBot'a Sor
    Yorum Ekle
  7. PowerBook G4 Titanium Mercury DVD Drive Replacement: adım 8, 1 resimden 1.
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    FixBot'a Sor
    Yorum Ekle
  8. PowerBook G4 Titanium Mercury DVD Drive Replacement: adım 9, 1 resimden 1.
    • Turn the G4 over.
    • Disconnect both orange ribbon cables from the logic board using a spudger or the tip of your finger.
    FixBot'a Sor
    Yorum Ekle
  9. PowerBook G4 Titanium Mercury DVD Drive Replacement: adım 10, 1 resimden 1.
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 49
Her zaman: 12,827
