Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
How to replace the non-standard DVD drive. Upgrading to a newer drive requires special brackets and cables.
Neye ihtiyacın var
Remove the battery.
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
5 farklı kişi bu kılavuzu tamamladı.
