Ana içeriğe geç
PowerBook G4 Titanium Mercury Display Replacement
Neye ihtiyacın var
  1. PowerBook G4 Titanium Mercury Display Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G4 Titanium Mercury Display Replacement: adım 2, 1 resimden 1.
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G4 Titanium Mercury Display Replacement: adım 3, 1 resimden 1.
    • Your laptop should look approximately like this.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G4 Titanium Mercury Display Replacement, RAM: adım 4, 1 resimden 1.
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    FixBot'a Sor
    Yorum Ekle
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G4 Titanium Mercury Display Replacement: adım 6, 1 resimden 1.
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook G4 Titanium Mercury Display Replacement: adım 7, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  7. PowerBook G4 Titanium Mercury Display Replacement, Airport Card: adım 8, 1 resimden 1.
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    FixBot'a Sor
    Yorum Ekle
  8. PowerBook G4 Titanium Mercury Display Replacement, Hard Drive: adım 9, 1 resimden 1.
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    FixBot'a Sor
    Yorum Ekle
  9. PowerBook G4 Titanium Mercury Display Replacement: adım 10, 1 resimden 1.
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    FixBot'a Sor
    Yorum Ekle
  10. PowerBook G4 Titanium Mercury Display Replacement: adım 11, 1 resimden 1.
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    FixBot'a Sor
    Yorum Ekle
  11. PowerBook G4 Titanium Mercury Display Replacement: adım 12, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  12. PowerBook G4 Titanium Mercury Display Replacement, DVD Drive: adım 13, 1 resimden 1.
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
    • Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
    FixBot'a Sor
    Yorum Ekle
  13. PowerBook G4 Titanium Mercury Display Replacement: adım 14, 1 resimden 1.
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    FixBot'a Sor
    Yorum Ekle
  14. PowerBook G4 Titanium Mercury Display Replacement: adım 15, 1 resimden 1.
    • Turn the G4 over.
    • Disconnect both orange ribbon cables from the logic board using a spudger or the tip of your finger.
    FixBot'a Sor
    Yorum Ekle
  15. PowerBook G4 Titanium Mercury Display Replacement: adım 16, 1 resimden 1.
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    FixBot'a Sor
    Yorum Ekle
  16. PowerBook G4 Titanium Mercury Display Replacement, Modem: adım 17, 1 resimden 1.
    • Turn the G4 over.
    • Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
    FixBot'a Sor
    Yorum Ekle
  17. PowerBook G4 Titanium Mercury Display Replacement: adım 18, 1 resimden 1.
    • Lift the modem out by pulling up and to the right.
    • The plastic shielding on the modem may catch on the computer's case. Rocking the modem from side to side will help free the modem.
    FixBot'a Sor
    Yorum Ekle
  18. PowerBook G4 Titanium Mercury Display Replacement: adım 19, 1 resimden 1.
    • Disconnect the connector cable from the modem.
    FixBot'a Sor
    Yorum Ekle
  19. PowerBook G4 Titanium Mercury Display Replacement, PMU: adım 20, 1 resimden 1.
    • Turn the G4 over.
    • Peel the orange tape away from the three connectors on the PMU board. Leave this tape in place so you can reuse it when reassembling the G4.
    • Disconnect the two orange cables and one multicolored cable from the PMU.
    FixBot'a Sor
    Yorum Ekle
  20. PowerBook G4 Titanium Mercury Display Replacement: adım 21, 1 resimden 1.
    • Lift up on the silver metal clip to free the PMU from the casing.
    • Remove the PMU rotating it clockwise and pulling up.
    FixBot'a Sor
    Yorum Ekle
  21. PowerBook G4 Titanium Mercury Display Replacement: adım 22, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  22. PowerBook G4 Titanium Mercury Display Replacement, Logic Board: adım 23, 1 resimden 1.
    • Turn the G4 over and rest it on a soft cloth.
    • Disconnect the multicolored fan connector and battery connector from the logic board.
    • Disconnect the orange PC card cage connector from the logic board.
    FixBot'a Sor
    Yorum Ekle
  23. PowerBook G4 Titanium Mercury Display Replacement: adım 24, 1 resimden 1.
    • Remove the single T8 Torx screw located next to the PC Card cage.
    FixBot'a Sor
    Yorum Ekle
  24. PowerBook G4 Titanium Mercury Display Replacement: adım 25, 1 resimden 1.
    • Turn the G4 over.
    • Remove the two T8 Torx screws from the middle of the logic board.
    FixBot'a Sor
    Yorum Ekle
  25. PowerBook G4 Titanium Mercury Display Replacement: adım 26, 1 resimden 1.
    • Disconnect the four indicated connectors from the logic board, removing tape as necessary.
    FixBot'a Sor
    Yorum Ekle
  26. PowerBook G4 Titanium Mercury Display Replacement: adım 27, 1 resimden 1.
    • Carefully lift the logic board up and pull it away from you. The logic board may catch on the back panel ports liner. If this occurs, use a spudger or non-metal tool to free the logic board.
    • This step requires some force, but if the logic board will not come up, make sure you have removed all screws and connectors necessary.
    • Remove the logic board from the computer.
    FixBot'a Sor
    Yorum Ekle
  27. PowerBook G4 Titanium Mercury Display Replacement: adım 28, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  28. PowerBook G4 Titanium Mercury Display Replacement, PC Card Cage: adım 29, 1 resimden 1.
    • Remove the two T8 Torx screws that secure the PC Card cage.
    FixBot'a Sor
    Yorum Ekle
  29. PowerBook G4 Titanium Mercury Display Replacement: adım 30, 1 resimden 1.
    • Remove the PC Card cage by pulling it to the right and twisting slightly toward you.
    FixBot'a Sor
    Yorum Ekle
  30. PowerBook G4 Titanium Mercury Display Replacement, Display: adım 31, 1 resimden 1.
    • Performing the following steps incorrectly can easily damage the display and render it inoperable. The multicolor display data cable is especially fragile.
    • Position the display at a 45 degree angle and rest the computer on a cloth with the back panel ports facing up. Remove the two T8 Torx screws from each clutch cover.
    FixBot'a Sor
    Yorum Ekle
  31. PowerBook G4 Titanium Mercury Display Replacement: adım 32, 1 resimden 1.
    • Close the display and pull off both clutch covers. You can use a non-metal flathead screwdriver if the clutch covers do not come off easily.
    FixBot'a Sor
    Yorum Ekle
  32. PowerBook G4 Titanium Mercury Display Replacement: adım 33, 1 resimden 1.
    • Open the display to a 90 degree angle. Rest the trackpad face down on the work surface and allow the display to hang over the edge. If possible, adjust your chair or work surface height so the display will rest on your legs and the upper case will lie flat on the work surface. If you cannot make this adjustment, you can remove the display with the screen closed. We recommend removing the display with the screen open in order to avoid changing the position of the hinges once the display has been removed.
    FixBot'a Sor
    Yorum Ekle
  33. PowerBook G4 Titanium Mercury Display Replacement: adım 34, 1 resimden 1.
    • Remove the four Phillips screws which fasten the display to the upper case.
    • The screw closest to the display data cable has a tapered head.
    FixBot'a Sor
    Yorum Ekle
  34. PowerBook G4 Titanium Mercury Display Replacement: adım 35, 1 resimden 1.
    • Lift up the metal brackets on either side of the upper case.
    • Disconnect the inverter cable and carefully thread it through the slot in the upper case.
    FixBot'a Sor
    Yorum Ekle
  35. PowerBook G4 Titanium Mercury Display Replacement: adım 36, 1 resimden 1.
    • Carefully thread the display and backlight cables individually through the slot in the upper case. Be very careful with the display cable and it is easily damaged.
    • Remove the display assembly.
    FixBot'a Sor
    Yorum Ekle
  36. PowerBook G4 Titanium Mercury Display Replacement: adım 37, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 69
Her zaman: 18,737
