Ana içeriğe geç
PowerBook G4 Titanium Onyx DVD Drive Replacement
Neye ihtiyacın var
  1. PowerBook G4 Titanium Onyx DVD Drive Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 2, 1 resimden 1.
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 3, 1 resimden 1.
    • Your laptop should look approximately like this.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G4 Titanium Onyx DVD Drive Replacement, RAM: adım 4, 1 resimden 1.
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    FixBot'a Sor
    Yorum Ekle
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 6, 1 resimden 1.
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 7, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  7. PowerBook G4 Titanium Onyx DVD Drive Replacement, Airport Card: adım 8, 1 resimden 1.
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    FixBot'a Sor
    Yorum Ekle
  8. PowerBook G4 Titanium Onyx DVD Drive Replacement, Hard Drive: adım 9, 1 resimden 1.
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
    FixBot'a Sor
    Yorum Ekle
  9. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 10, 1 resimden 1.
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    FixBot'a Sor
    Yorum Ekle
  10. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 11, 1 resimden 1.
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    FixBot'a Sor
    Yorum Ekle
  11. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 12, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  12. PowerBook G4 Titanium Onyx DVD Drive Replacement, DVD Drive: adım 13, 1 resimden 1.
    • If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
    FixBot'a Sor
    Yorum Ekle
  13. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 14, 1 resimden 1.
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    FixBot'a Sor
    Yorum Ekle
  14. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 15, 1 resimden 1.
    • Turn the G4 over.
    • Disconnect the orange DVD ribbon cable from the logic board using a spudger or the tip of your finger
    FixBot'a Sor
    Yorum Ekle
  15. PowerBook G4 Titanium Onyx DVD Drive Replacement: adım 16, 1 resimden 1.
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
1Rehber Yorum
I need the connector 4 this ... Can't find it anywhere
PeNn N RoMe - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 50
Her zaman: 10,050
