Ana içeriğe geç
PowerLead Puto PLD003 Back Buttons Replacement
Neye ihtiyacın var
    1. PowerLead Puto PLD003 Back Buttons Replacement, Side Panel: adım 1, 1 resimden 1.
      • Slide the battery eject button open to release the battery door.
      FixBot'a Sor
      Yorum Ekle
    2. PowerLead Puto PLD003 Back Buttons Replacement: adım 2, 1 resimden 1.
      • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    3. PowerLead Puto PLD003 Back Buttons Replacement: adım 3, 1 resimden 1.
      • Rotate the camera so that the underside is facing up.
      • Remove the four 5 mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    4. PowerLead Puto PLD003 Back Buttons Replacement: adım 4, 1 resimden 1.
      • Place the camera on a flat surface, with its underside facing you.
      • Gently pull up on the side panel to remove it from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: adım 5, 2 resimden 1. PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: adım 5, 2 resimden 2.
      • Remove the three 4 mm Phillips #1 screws holding the weight.
      • Remove the weight.
      FixBot'a Sor
      Yorum Ekle
    2. PowerLead Puto PLD003 Back Buttons Replacement: adım 6, 1 resimden 1.
      • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
      FixBot'a Sor
      Yorum Ekle
    3. PowerLead Puto PLD003 Back Buttons Replacement: adım 7, 1 resimden 1.
      • Apply pressure to the back panel, away from the camera to remove.
      FixBot'a Sor
      Yorum Ekle
    4. PowerLead Puto PLD003 Back Buttons Replacement: adım 8, 2 resimden 1. PowerLead Puto PLD003 Back Buttons Replacement: adım 8, 2 resimden 2.
      • Place the back panel so the buttons are facing down and the circuit board is facing up.
      • Remove the three 4 mm Phillips #1 screws holding the circuit board in place.
      FixBot'a Sor
      Yorum Ekle
    5. PowerLead Puto PLD003 Back Buttons Replacement: adım 9, 1 resimden 1.
      • Set aside the circuit board.
      • These nubs are what is currently holding the buttons in place.
      • Carefully apply pressure and remove the set of buttons from the nubs.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 460
