Ana içeriğe geç
PowerLead Puto PLD003 Side Panel Replacement
Neye ihtiyacın var
  1. PowerLead Puto PLD003 Side Panel Replacement, Side Panel: adım 1, 1 resimden 1.
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Side Panel Replacement: adım 2, 1 resimden 1.
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Side Panel Replacement: adım 3, 1 resimden 1.
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Side Panel Replacement: adım 4, 1 resimden 1.
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 172
