Ana içeriğe geç
PowerShot G7 X Mark II Front Cover Replacement
Neye ihtiyacın var
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: adım 1, 2 resimden 1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: adım 1, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: adım 2, 2 resimden 1. PowerShot G7 X Mark II Front Cover Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left of the camera.
  4. PowerShot G7 X Mark II Front Cover Replacement: adım 4, 2 resimden 1. PowerShot G7 X Mark II Front Cover Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Front Cover Replacement: adım 5, 2 resimden 1. PowerShot G7 X Mark II Front Cover Replacement: adım 5, 2 resimden 2.
    • Carefully remove the back cover off of the camera by hand. Press the brown actuator in the FFC socket to release the FPC (Flexible Printed Circuit - brown cable attached to the back cover) and pull the FPC out of the socket.
    • If the FPC doesn't come out easily, you haven't yet released it. Do not force it. Do not use a spudger because it will break the socket. A broken socket cannot be fixed and has to be replaced by a skilled technician.
  6. PowerShot G7 X Mark II Front Cover Replacement: adım 6, 2 resimden 1. PowerShot G7 X Mark II Front Cover Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Front Cover Replacement: adım 7, 2 resimden 1. PowerShot G7 X Mark II Front Cover Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: adım 8, 3 resimden 1. PowerShot G7 X Mark II Front Cover Replacement: adım 8, 3 resimden 2. PowerShot G7 X Mark II Front Cover Replacement: adım 8, 3 resimden 3.
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Front Cover Replacement: adım 9, 2 resimden 1. PowerShot G7 X Mark II Front Cover Replacement: adım 9, 2 resimden 2.
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: adım 10, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
  11. PowerShot G7 X Mark II Front Cover Replacement: adım 11, 1 resimden 1.
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: adım 12, 1 resimden 1.
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon
626 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G3
3 Üyeler
2Kılavuz Yorumları
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - Yanıt
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
Momchil Panayotov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 4,343
