Ana içeriğe geç
PowerShot G7 X Mark II LCD Screen Replacement
Neye ihtiyacın var
    1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
      • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    2. PowerShot G7 X Mark II LCD Screen Replacement: adım 2, 1 resimden 1.
      • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: adım 3, 1 resimden 1.
      • Use a spudger tool to release the ribbon cable from the ZIF connector.
      • The cable is thin and delicate. Detach with care.
      • Gently pry off the screen until the double-sided tape behind the back panel gives in.
      FixBot'a Sor
      Yorum Ekle
    4. PowerShot G7 X Mark II LCD Screen Replacement: adım 4, 1 resimden 1.
      • The screen is detached and can now be replaced.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Brandon
644 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G3
3 Üyeler
5Kılavuz Yorumları
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - Yanıt Paylaş
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - Yanıt Paylaş
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali - Yanıt Paylaş
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - Yanıt Paylaş
on ebay or amazon. you can order it
nicole - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 45
Son 30 gün: 184
Her zaman: 12,381
