Ana içeriğe geç
Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
Neye ihtiyacın var
  1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: adım 1, 2 resimden 1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: adım 1, 2 resimden 2.
    • Plug in the tree.
    • Use a Christmas light function tester to check the fuse on a light that is not bright.
    • The red light on the function tester will not light up if the fuse is dead.
  2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 2, 1 resimden 1.
    • Unplug the tree from the outlet.
  3. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 3, 3 resimden 1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 3, 3 resimden 2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 3, 3 resimden 3.
    • Open the fuse cover, then use a small flathead screwdriver or spudger to carefully remove the fuse.
  4. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 4, 1 resimden 1.
    • Using a continuity tester and the fuse, place both tips of the continuity tester on either side of the fuse.
    • The top light should light up red if the fuse is in working condition. If no light appears, repeat this step with a new fuse.
  5. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 5, 3 resimden 1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 5, 3 resimden 2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 5, 3 resimden 3.
    • Carefully insert the working fuse back into the tree plug, and put the cover on.
  6. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 6, 1 resimden 1.
    • Plug the tree back into the outlet.
  7. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: adım 7, 1 resimden 1.
    • Using the Christmas light function tester, go back to the same spot you initially checked. If the red light appears, you have successfully replaced the fuse!
    • The red light will appear whether the bulb itself is working or not.
Sonuç
Thank you for using this guide!
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 2,166
