Ana içeriğe geç
Prep Black Wire
Neye ihtiyacın var
  1. Prep Black Wire, Wire: adım 1, 1 resimden 1.
    • Locate QCPN#10669 which is a black hookup wire.
  2. Prep Black Wire: adım 2, 3 resimden 1. Prep Black Wire: adım 2, 3 resimden 2. Prep Black Wire: adım 2, 3 resimden 3.
    • Measure out a 10cm length of wire.
    • Use a pair of flash cutters to carefully cut through the wire.
    • Caution: the wire must be no longer than 10.5cm and no shorter than 9.5cm in length.
  3. Prep Black Wire: adım 3, 1 resimden 1.
    • Your wire should look like this now. #testedit
  4. Prep Black Wire: adım 4, 2 resimden 1. Prep Black Wire: adım 4, 2 resimden 2.
    • Measure 20mm from either end of the wire.
    • With the flash cutters remove the instulation that is covering the wire.
    • Be careful not to cut to deep because you will damage the wire strands inside.
  5. Prep Black Wire: adım 5, 2 resimden 1. Prep Black Wire: adım 5, 2 resimden 2.
    • Measure 10mm from the other side of the wire.
    • Remove the insulation from the wire with a pair of flash cutters.
  6. Prep Black Wire: adım 6, 1 resimden 1.
    • Your finished wire should now look like this.
    • Remember to twist of the ends of the wire with your fingers so that the wire strands are not loose.
Sonuç
You are finished.
6 farklı kişi bu kılavuzu tamamladı.
Russell Frampton
356 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 430
