Ana içeriğe geç
Presto PopLite 04820 Popping Chamber Base Replacement
Neye ihtiyacın var
  1. Presto PopLite 04820 Popping Chamber Base Replacement, Baseplate: adım 1, 1 resimden 1.
    • Be sure that the popper is unplugged before disassembly.
    • Turn Presto Popper upside down.
  2. Presto PopLite 04820 Popping Chamber Base Replacement: adım 2, 3 resimden 1. Presto PopLite 04820 Popping Chamber Base Replacement: adım 2, 3 resimden 2. Presto PopLite 04820 Popping Chamber Base Replacement: adım 2, 3 resimden 3.
    • Remove the four 9 mm Phillips #2 screws from the base.
    • Once all four screws are removed, take the base off.
  3. Presto PopLite 04820 Popping Chamber Base Replacement, Popping Chamber Base: adım 3, 2 resimden 1. Presto PopLite 04820 Popping Chamber Base Replacement, Popping Chamber Base: adım 3, 2 resimden 2.
    • Remove the four 13 mm Phillips #2 screws.
  4. Presto PopLite 04820 Popping Chamber Base Replacement: adım 4, 1 resimden 1.
    • Remove the entire cavity that holds the motor from the base of the PopLite.
    • Be gentle while taking the motor out of the base to avoid wire damage.
  5. Presto PopLite 04820 Popping Chamber Base Replacement: adım 5, 2 resimden 1. Presto PopLite 04820 Popping Chamber Base Replacement: adım 5, 2 resimden 2.
    • Turn the popping chamber base sideways.
    • Now remove popping chamber base.
Sonuç
Emanuele Rocco
694 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Blackwell Fall 2015 USF Tampa, Team 2-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G5
2 Üyeler
Bir Yorum
Where can I get the new base from?
Barry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 613
