Ana içeriğe geç
Presto PopLite 04820 Popping Chamber Shaft Replacement
Neye ihtiyacın var
  1. Presto PopLite 04820 Popping Chamber Shaft Replacement, Chute: adım 1, 1 resimden 1.
    • Make sure you unplug the device before disassembling.
    • Remove the butter melter/measuring cup.
  2. Presto PopLite 04820 Popping Chamber Shaft Replacement: adım 2, 1 resimden 1.
    • Remove the cover.
  3. Presto PopLite 04820 Popping Chamber Shaft Replacement: adım 3, 3 resimden 1. Presto PopLite 04820 Popping Chamber Shaft Replacement: adım 3, 3 resimden 2. Presto PopLite 04820 Popping Chamber Shaft Replacement: adım 3, 3 resimden 3.
    • Remove the three 49 mm Phillips #2 screws.
    • Once you have removed the screws, remove the chute from popper base.
  4. Presto PopLite 04820 Popping Chamber Shaft Replacement, Popping Chamber Shaft: adım 4, 1 resimden 1.
    • The popping chamber shaft should be located in the popper base once the chute is removed.
  5. Presto PopLite 04820 Popping Chamber Shaft Replacement: adım 5, 2 resimden 1. Presto PopLite 04820 Popping Chamber Shaft Replacement: adım 5, 2 resimden 2.
    • Reach down the popper base and grab the popping chamber shaft. Begin to remove it from the popper base.
    • Now remove it completely and set it aside for new shaft to be placed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emanuele Rocco
694 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Blackwell Fall 2015 USF Tampa, Team 2-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 12
Her zaman: 361
