Ana içeriğe geç
Presto Stirring Popper 0520002 Disassembly
Neye ihtiyacın var
  1. Presto Stirring Popper 0520002 Disassembly, Presto Stirring Popper 0520002 Disassembly: adım 1, 1 resimden 1.
    • Detach the cover/serving bowl from the popper.
    • Flip the base of the popper over and remove the four 14 mm Phillips #2 screws attaching the bottom cover to the base.
  2. Presto Stirring Popper 0520002 Disassembly: adım 2, 2 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 2, 2 resimden 2.
    • Removing the bottom cover exposes the internals of the popper. The base holds together the centrally mounted motor and the wires for the power cord and heating element.
  3. Presto Stirring Popper 0520002 Disassembly: adım 3, 3 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 3, 3 resimden 2. Presto Stirring Popper 0520002 Disassembly: adım 3, 3 resimden 3.
    • Remove the two black wire twist caps, and unwind the different wires.
    • During reassembly, make sure the wires are strongly twisted together (twist clockwise) and the wire caps are firmly attached.
    • Avoid swapping the polarity during reassembly. The neutral (ridged) wire connects to the left motor wire and the white wire to the heater.
    • Remove two more 14 mm Phillips #2 screws attaching the white plastic holding the wall cord to the base.
  4. Presto Stirring Popper 0520002 Disassembly: adım 4, 3 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 4, 3 resimden 2. Presto Stirring Popper 0520002 Disassembly: adım 4, 3 resimden 3.
    • Remove the two 14 mm Phillips #2 screws from the motor.
    • Remove the motor from the popper.
    • A spring located in the shaft may force the motor out when the screws are sufficiently loosened.
  5. Presto Stirring Popper 0520002 Disassembly: adım 5, 1 resimden 1.
    • Remove the four 50 mm screws attaching the base to the heating pan.
    • Removing these screws takes significant force.
  6. Presto Stirring Popper 0520002 Disassembly: adım 6, 1 resimden 1.
    • Remove the base from the rest of the device.
  7. Presto Stirring Popper 0520002 Disassembly: adım 7, 2 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 7, 2 resimden 2.
    • This is the nonstick heating pan with the stirrer still attached.
    • The pan surface can be greasy from use.
  8. Presto Stirring Popper 0520002 Disassembly: adım 8, 3 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 8, 3 resimden 2. Presto Stirring Popper 0520002 Disassembly: adım 8, 3 resimden 3.
    • The center stirring arm knob can be removed by hand (twisting to the left).
    • The scalloped stirring arm can be directly lifted out from the center mount.
    • During reassembly, note that the scalloped stirring arm is keyed to fit in one direction.
  9. Presto Stirring Popper 0520002 Disassembly: adım 9, 2 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 9, 2 resimden 2.
    • Flipping the heating pan over, wires to the thermostat and the plastic motor shaft remain.
  10. Presto Stirring Popper 0520002 Disassembly: adım 10, 2 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 10, 2 resimden 2.
    • Directly pull the motor shaft out.
    • Take care to not misplace the small spring.
  11. Presto Stirring Popper 0520002 Disassembly: adım 11, 3 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 11, 3 resimden 2. Presto Stirring Popper 0520002 Disassembly: adım 11, 3 resimden 3.
    • Remove two Phillips screws to detach the thermostat.
  12. Presto Stirring Popper 0520002 Disassembly: adım 12, 2 resimden 1. Presto Stirring Popper 0520002 Disassembly: adım 12, 2 resimden 2.
    • This is the heating plate with the rubber gasket removed.
    • During reassembly, be sure to re-attach the gasket around the entire plate before reassembling the bowl.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 326
