Ana içeriğe geç
Princess Compact Blender Rubber Gasket Replacement
Neye ihtiyacın var
  1. Princess Compact Blender Rubber Gasket Replacement, Rubber Gasket: adım 1, 1 resimden 1.
    • Lift the glass container of the motor
    • The motor is the bottom part of the blender
    • If your blender has recently been used, you may want to clean it before taking it apart
  2. Princess Compact Blender Rubber Gasket Replacement: adım 2, 2 resimden 1. Princess Compact Blender Rubber Gasket Replacement: adım 2, 2 resimden 2.
    • Unscrew the base from the glass container. The right direction is indicated by the red arrow.
    • The base is the part whereon the blades are attached
  3. Princess Compact Blender Rubber Gasket Replacement: adım 3, 1 resimden 1.
    • Lift metal blades with the metal hood out of the base
    • Watch out for sharp blades or wear gloves
    • Large rubber ring may fall out of the base, this is no problem, just put it back in place
  4. Princess Compact Blender Rubber Gasket Replacement: adım 4, 2 resimden 1. Princess Compact Blender Rubber Gasket Replacement: adım 4, 2 resimden 2.
    • Take the cutting blades in one hand and the black, plastic connector part in the other
    • This is where you could use the gloves
    • Unscrew the latter together with the screw-nut from the axis by twisting
    • If necessary, apply a little force to slightly pull it out
    • To unscrew, you have to twist right. The “righty tighty, lefty loosy-principle” does not apply here
  5. Princess Compact Blender Rubber Gasket Replacement: adım 5, 1 resimden 1.
    • Gently slide off the hood and lower, small metal protective ring from the axis and don’t lose the rubber ring!
  6. Princess Compact Blender Rubber Gasket Replacement: adım 6, 2 resimden 1. Princess Compact Blender Rubber Gasket Replacement: adım 6, 2 resimden 2.
    • Slide the broken ring off the axis
    • Replace the broken ring for a new one
  7. Princess Compact Blender Rubber Gasket Replacement: adım 7, 3 resimden 1. Princess Compact Blender Rubber Gasket Replacement: adım 7, 3 resimden 2. Princess Compact Blender Rubber Gasket Replacement: adım 7, 3 resimden 3.
    • Slide the remaining parts back on the axis in the following order:
    • Metal hood
    • Small metal protective ring
    • Black plastic connector
    • Screw back the screw-nut on the thread with the pliers to fasten the assembly
    • Put the blade-assembly back in the base
  8. Princess Compact Blender Rubber Gasket Replacement: adım 8, 3 resimden 1. Princess Compact Blender Rubber Gasket Replacement: adım 8, 3 resimden 2. Princess Compact Blender Rubber Gasket Replacement: adım 8, 3 resimden 3.
    • Twist the base back onto the glass container
    • Put the glass container on the stand (bottom part of the blender, containing the motor)
    • Start making your smoothie!
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 41
Her zaman: 3,006
