Ana içeriğe geç
Printer setup in Linux (Mint, etc)
Neye ihtiyacın var
      • Connect the printer to your computer with a USB cable.
      • The USB-B plug goes in the back of the printer.
      • Make sure the computer and printer are both switched on.
      FixBot'a Sor
      Yorum Ekle
      • Go to Start menu > System > Printers if it hasn't opened automatically.
      • Now click Add printer and look for the make and model.
      • If you see XP-220 listed in the Epson category, your computer probably has the correct Epson printer driver and you can skip to Step 4.
      • If you don't see XP-220 as an option, pause here and open the software installer (under Start menu > System by default).
      FixBot'a Sor
      Yorum Ekle
      • Linux Mint's stock software "store" has the Epson driver easily available. Search "epson" and the driver should come up as one of, if not the first option.
      • Click Install. Type in the superuser password it asks for (depending on how your account is set up, this may be your own password or an admin's password).
      FixBot'a Sor
      Yorum Ekle
      • When the printer driver is installed, go back to the printer setup.
      • Now when you add your printer, XP-220 will appear in the long list of Epson models. Select that and the computer will now connect to the printer easily.
      FixBot'a Sor
      Yorum Ekle
      • You can print a test page to make sure the printer is working.
      FixBot'a Sor
      Yorum Ekle
Sonuç
This is written for Linux Mint, but also applies to other Linux distributions with similar menu options.
Bir başkası bu kılavuzu tamamladı.
Sparky
1.535 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 23
