Ana içeriğe geç
ProLine HB25 Disassembly
Neye ihtiyacın var
    1. ProLine HB25 Disassembly, ProLine HB25 Disassembly: adım 1, 1 resimden 1.
      • Unscrew the screw on the back of the product.
      FixBot'a Sor
      Yorum Ekle
    2. ProLine HB25 Disassembly: adım 2, 2 resimden 1. ProLine HB25 Disassembly: adım 2, 2 resimden 2.
      • Pull out the backtab of the housing.
      • Push in the snapfits with, for instance, a screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. ProLine HB25 Disassembly: adım 3, 2 resimden 1. ProLine HB25 Disassembly: adım 3, 2 resimden 2.
      • Separate the housing with calibrated force.
      • Keep your fingers away from the housing and do not bend or break the housing.
      • Use a flathead screwdriver to push out the lower function button.
      • Remove the separating device.
      FixBot'a Sor
      Yorum Ekle
    4. ProLine HB25 Disassembly: adım 4, 1 resimden 1.
      • Unscrew the hidden screw under the button.
      FixBot'a Sor
      Yorum Ekle
    5. ProLine HB25 Disassembly: adım 5, 2 resimden 1. ProLine HB25 Disassembly: adım 5, 2 resimden 2.
      • Open the housing.
      • Unscrew the circuit board.
      • Unscrew the wire lock.
      FixBot'a Sor
      Yorum Ekle
    6. ProLine HB25 Disassembly: adım 6, 2 resimden 1. ProLine HB25 Disassembly: adım 6, 2 resimden 2.
      • Push the housing of the button out of the housing.
      FixBot'a Sor
      Yorum Ekle
    7. ProLine HB25 Disassembly: adım 7, 2 resimden 1. ProLine HB25 Disassembly: adım 7, 2 resimden 2.
      • Push on the side of the housing of the button to push the button out of the housing.
      • The spring can jump away when you push out the button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 720
