Ana içeriğe geç
ProScan PLT7050 Battery Replacement
Neye ihtiyacın var
  1. ProScan PLT7050 Battery Replacement, Open Device: adım 1, 1 resimden 1.
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. ProScan PLT7050 Battery Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
    FixBot'a Sor
    Yorum Ekle
  3. ProScan PLT7050 Battery Replacement, Battery: adım 3, 2 resimden 1. ProScan PLT7050 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Use the soldering tool to remove the wires from the motherboard. (Black and Red)
    • The soldering tool is hot.
    • Take note of where the wires are located.
    FixBot'a Sor
    Yorum Ekle
  4. ProScan PLT7050 Battery Replacement: adım 4, 2 resimden 1. ProScan PLT7050 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the black tape from the battery.
    • Remove the three pieces of yellow tape from the battery.
    FixBot'a Sor
    Yorum Ekle
  5. ProScan PLT7050 Battery Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to pry the battery from the device as it is attached by an adhesive.
    • Do not proceed if corrosion and/or swelling of the battery is visible.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,373
