Ana içeriğe geç
ProScan PLT7050 Camera Replacement
Neye ihtiyacın var
    1. ProScan PLT7050 Camera Replacement, Open Device: adım 1, 1 resimden 1.
      • Make sure device is unplugged and turned off while working on the device.
      • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. ProScan PLT7050 Camera Replacement: adım 2, 1 resimden 1.
      • Use the plastic opening tools to pry the back of the tablet open.
      • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
      • May be helpful if you start by the microSD slot.
      FixBot'a Sor
      Yorum Ekle
    1. ProScan PLT7050 Camera Replacement, Camera: adım 3, 1 resimden 1.
      • Remove the black tape carefully.
      FixBot'a Sor
      Yorum Ekle
    2. ProScan PLT7050 Camera Replacement: adım 4, 1 resimden 1.
      • Use the plastic opening tool to open the ZIF connector tab to release the camera's ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    3. ProScan PLT7050 Camera Replacement: adım 5, 1 resimden 1.
      • Remove the camera's ribbon cable.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 395
