Ana içeriğe geç
ProScan PLT7050 Motherboard Replacement
Neye ihtiyacın var
  1. ProScan PLT7050 Motherboard Replacement, Open Device: adım 1, 1 resimden 1.
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. ProScan PLT7050 Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the 3 black pieces of tape from the device.
    • Remove the 5 yellow pieces of tape from the device.
  4. ProScan PLT7050 Motherboard Replacement: adım 4, 2 resimden 1. ProScan PLT7050 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the soldering tool to remove the 3 wires from the mother board to the battery (black, red, gray).
    • Soldering tool will get hot.
  5. ProScan PLT7050 Motherboard Replacement: adım 5, 2 resimden 1. ProScan PLT7050 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the speaker wires from the motherboard with the soldering tool.
  6. ProScan PLT7050 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove 3 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  7. ProScan PLT7050 Motherboard Replacement: adım 7, 3 resimden 1. ProScan PLT7050 Motherboard Replacement: adım 7, 3 resimden 2. ProScan PLT7050 Motherboard Replacement: adım 7, 3 resimden 3.
    • Use the plastic opening tool to pop open all 3 ZIF connector tabs connected to the motherboard.
    • Remove each ribbon from the ZIF connector port.
  8. ProScan PLT7050 Motherboard Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard off the device taking care to pull the ports out of the casing.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 349
