Ana içeriğe geç
ProScan PLT7050 Screen Replacement
Neye ihtiyacın var
  1. ProScan PLT7050 Screen Replacement, Open Device: adım 1, 1 resimden 1.
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Screen Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Screen Replacement, Motherboard: adım 3, 2 resimden 1. ProScan PLT7050 Screen Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the 3 black pieces of tape from the device.
    • Remove the 5 yellow pieces of tape from the device.
  4. ProScan PLT7050 Screen Replacement: adım 4, 2 resimden 1. ProScan PLT7050 Screen Replacement: adım 4, 2 resimden 2.
    • Use the soldering tool to remove the 3 wires from the mother board to the battery (black, red, gray).
    • Soldering tool will get hot.
  5. ProScan PLT7050 Screen Replacement: adım 5, 2 resimden 1. ProScan PLT7050 Screen Replacement: adım 5, 2 resimden 2.
    • Remove the speaker wires from the motherboard with the soldering tool.
  6. ProScan PLT7050 Screen Replacement: adım 6, 1 resimden 1.
    • Remove 3 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  7. ProScan PLT7050 Screen Replacement: adım 7, 3 resimden 1. ProScan PLT7050 Screen Replacement: adım 7, 3 resimden 2. ProScan PLT7050 Screen Replacement: adım 7, 3 resimden 3.
    • Use the plastic opening tool to pop open all 3 ZIF connector tabs connected to the motherboard.
    • Remove each ribbon from the ZIF connector port.
  8. ProScan PLT7050 Screen Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard off the device taking care to pull the ports out of the casing.
  9. ProScan PLT7050 Screen Replacement, Screen: adım 9, 3 resimden 1. ProScan PLT7050 Screen Replacement, Screen: adım 9, 3 resimden 2. ProScan PLT7050 Screen Replacement, Screen: adım 9, 3 resimden 3.
    • You will need two plastic opening tools.
    • Use one of the plastic opening tools next to one of the black clips on the side of silver screen.
    • Use the second plastic opening tool to push back the black clip next to the one you have worked on. Push the second plastic opening tool under the screen.
  10. ProScan PLT7050 Screen Replacement: adım 10, 1 resimden 1.
    • Wiggle the screen and pull it from the casing.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 305
