Ana içeriğe geç
ProScan PLT7050 Speaker Replacement
Neye ihtiyacın var
  1. ProScan PLT7050 Speaker Replacement, Open Device: adım 1, 1 resimden 1.
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Speaker Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove the yellow tape.
  4. ProScan PLT7050 Speaker Replacement: adım 4, 2 resimden 1. ProScan PLT7050 Speaker Replacement: adım 4, 2 resimden 2.
    • Use the soldering tool to remove the two speaker wires from the mother board.
    • Take note of where the wires are located.
    • Soldering tool will get hot.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 170
