Ana içeriğe geç
ProScan PLT7223G Battery Replacement
Neye ihtiyacın var
    1. ProScan PLT7223G Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. ProScan PLT7223G Battery Replacement: adım 2, 1 resimden 1.
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. ProScan PLT7223G Battery Replacement: adım 3, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
      • Be sure to pay attention to where each wire goes so that you attach them in the correct order when reassembling the device.
      • Soldering tool will get hot, handle with care.
      FixBot'a Sor
      Yorum Ekle
    4. ProScan PLT7223G Battery Replacement: adım 4, 1 resimden 1.
      • Use a spudger to remove the black tape from the battery.
      FixBot'a Sor
      Yorum Ekle
    5. ProScan PLT7223G Battery Replacement: adım 5, 1 resimden 1.
      • Using the flat end of a spudger, carefully separate the battery from the base of the device.
      • There is an adhesive holding the charger in place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
what is the number of the replacement battery??
florcomm - Yanıt Paylaş
How will I know if my proscan tablet battery is no good once I remove it
Genica Harmon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 4,745
