Ana içeriğe geç
ProScan PLT7223G Battery Replacement
Neye ihtiyacın var
  1. ProScan PLT7223G Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
    FixBot'a Sor
  2. ProScan PLT7223G Battery Replacement: adım 2, 1 resimden 1.
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
    FixBot'a Sor
  3. ProScan PLT7223G Battery Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
    • Be sure to pay attention to where each wire goes so that you attach them in the correct order when reassembling the device.
    • Soldering tool will get hot, handle with care.
    FixBot'a Sor
  4. ProScan PLT7223G Battery Replacement: adım 4, 1 resimden 1.
    • Use a spudger to remove the black tape from the battery.
    FixBot'a Sor
  5. ProScan PLT7223G Battery Replacement: adım 5, 1 resimden 1.
    • Using the flat end of a spudger, carefully separate the battery from the base of the device.
    • There is an adhesive holding the charger in place.
    FixBot'a Sor
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
what is the number of the replacement battery??
florcomm - Yanıt Paylaş
How will I know if my proscan tablet battery is no good once I remove it
Genica Harmon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 61
Her zaman: 4,672
