Ana içeriğe geç
ProScan PLT7223G Front Facing Camera Replacement
Neye ihtiyacın var
    1. ProScan PLT7223G Front Facing Camera Replacement, Front Facing Camera: adım 1, 1 resimden 1.
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. ProScan PLT7223G Front Facing Camera Replacement: adım 2, 1 resimden 1.
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. ProScan PLT7223G Front Facing Camera Replacement: adım 3, 1 resimden 1.
      • With a spudger, flip up the ZIF connector that connects the camera's ribbon cable to the motherboard. This will release the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. ProScan PLT7223G Front Facing Camera Replacement: adım 4, 1 resimden 1.
      • Remove the black tape holding down the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    5. ProScan PLT7223G Front Facing Camera Replacement: adım 5, 1 resimden 1.
      • Remove camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 475
